Hi all I've fitted my ps3 in my van but have
No sound throught the stereo when using it
I have a hdmi lead to the tv and am using the av
Multi out for the audio going the the stereo any ideas
Cheers Russ
Cheers Russ
have you set the settings on the PS3 to use the multi-out? If you use HDMI, default setting is to output sound over HDMI. It's in the Sound section of the PS3's settings T:
I assume you've checked the leads are all plugged in, and you've turned the stereo to the right input too...:D
Hmmmmm think I was having a moment I didn't have controller
With me at the time I will be at the van on thurs so will check the settings
Cheers Russ
