Hey all
I have a 2.5 LWB petrol T4, I posted this problem here before but got nothing back.
I am have a issue with my van the problems is when I have being driving the van for anything longer than 15 min when I restart the engine after stopping it has problems starting. I have to pump the gas to get the van to run.
Q when you start yout motor you can here the fuel pump kicking in. Should I be hearing the fule pump even if the engine has beng running for a while.
I recently changed the OIL, PLUGS, THE CAP, CAP LEADS and coolant. It was happening before I gave the van a good service. I was hopeing that it was fix the issue.
Can anyone point me in the right direction. Fuel pump maybe!!!!
Thanks in advance.
I think I'm right in thinking that the petrols all use electric fuel pumps, which usually either work or they don't. My initial suspicion would probably be a temp sensor problem. Have you replaced the 2 pin water temp sensor? They are known to cause problems (although more usually with poor running) when they fail.
Hey Guys
Thanks for the replies. I will replace the water temp sensor today or tomorrow and keep you posted.
Fingers crossed I get to the bottom of this.
D
