Wondering if anyone can shred some light on an issue I have...Ive noticed lately that if I hill start in 1st gear the van seems to just die down and feel as if its going to stall.
Its had a new Sachs clutch kit fitted not long ago.
Its a 1.9TD
Thanks!
My 1.9td was like that, i fitted an EGR blanking plate and a decat pipe , its like a completely different van!! Amazing difference!
Dave
Its a 1.9TD
I:I:I:
My father has a 1.9TD and that used to struggle but now is a little bit better having had the EGR valve blanked off ( he wouldn't let me remove the CAT though..:bhd
Removal of the CAT would also help along with the EGR Valve clean and blank mentioned earlier.
That will allow the turbo to breathe more easily and to spool up faster.
Do you have access to Vagcom as there could be other potential faults.
Good Luck.
Do all of the above and remove the throttle cable and spray loads of WD40 down it frees it up real nice.
Also Jet black the 1.9TD does not have a vag com its got no ECU...
