Evening all..
I have a Fiamma 45’s awning fitted with the roof channel brackets fitted..
Am I still able to have a pop top fitted with this configuration ??
If not what is needed to make this happen as the extra space is needed..
TIA
John??
You'll need to swap the brackets possibly depending on what roof you install. My Reimo roof has specific brackets which are bolted into the roof skim with nutserts. I was a bit hessitant and to be honest I dont use the awning so I might end up removing it but at least the holes I drilled sit under the cover of the pop top so you'll never see them.
