Hello, I'm a bit stumped here and hope someone with more experience than me can help.
I recently had a 100K service and the timing belt changed on my 2001 2.5tdi T4. During the belt change the chap said he altered things a little as the marks on the pulleys didn't quite line up. The effect being the engine should run better.
Immediately after the belt was changed I noticed the engine fires up on the first turn (it wasn't bad before by any stretch but is definitely better). Now, however, I find there is a LOT less power all the way up to about 2000-2100rpm (but particularly between say 1700-2000) up until the turbo kicks in. The power curve was very smooth before right through the rev range and now it gets progressively more gutless until the turbo starts, which it does with an almost violent increase in power. The problem is such that pulling onto a busy roundabout is now very difficult/dangerous as the van is slow sluggish in the early rev range.
I took it back for the guy to have a look at, and although he didn't run any diagnostics he said what a number of other forum posts point to - that the air mass sensor (a bosch one) had given up. I don't want to waste the guys time by asking him to look at the engine again unless im sure and I really cant afford to have a diagnostic check done or by a new mass sensor on the off chance! Also, I find it hard to believe that the sensor happened to -out during the service.. a bit too much of a coincidence?! I disconnected the air mass sensor (as advised) to try driving with it disconnected and it feels a little better but the turbo has almost no effect.
Has anyone had a similar experience following a timing belt change?
Thanks in advance!
Thanks in advance!
