hi my power steering pump is leaking very badly. i bought a replacement second hand one as no way i can afford a new one.
took old one off fitted new one. everything fits fine but the pulleys do not line up.
the only difference i can see is the triangle flange bit the pulley bolts to on the pump is 10mm further out on the new pump. is there a way to swap the pulley flanges over?
i have an R reg 1.9 turbo diesel. thats all i know its a white 1.9 turbo diesel panel van
the one i bought from from a bloke on facebook said he had one that would fit.
fitted it and the pulleys are not lined up.
do the pulley flanges come off?
Ok have now swapped over pulley flanges and had to change the pipe union aswell. It all works perfectly. But could not find a bolt that fitted in the pump shaft. M8 to small and m10 to big so I'm guessing I have to find an m9 short bolt from somewhere?
