Hi - I've been noticing a that I am getting more an more problems selecting 5th gear when the van has been running after 10-15 miles. As I lift the clutch I just get the crunch of gears because the cogs haven't fully engaged.
It seems ok when cold and double de-clutching doesn't help. The only thing that seems to work is throwing the lever twice with the clutch disengaged i.e. going from 4th to 5th, back to neutral and then back to 5th.
This seems to be a viable work around for the moment but for how long I'm not sure. We managed to survive a trip from Shropshire to Dorset and back at the weekend but are off the France in August and would like to get it sorted before then.
If anyone has had the same issue or has any suggestions as to whether its might be a linkage or internal gearbox problem these will be gratefully received.
