1 - 9 of 9 Posts
Hi, folks, I thought i would refurbish the Projektzwo Headlights before i fit them, problem is them nasty little adjusters (see photo) are so brittle they break easy! Does anyone know if they are Hella parts or Projektzwo's own parts?
Any help would be appreciated.
Also any info on adjusting them as not to blind british drivers!
Thanks.
In that pic they look similar to the original T4 headlight adjusters which i had to replace on my previous T4 because the headlights were loose. I bought them direct from VW for a couple of quid. It might be worth checking:dunno:
Cheers Bodhi, just checked my standard lights, they are similar but larger on the Standard lights..
I've got some ordered now from: projektzwo importers.
RSD Road and Sport Developments
Unit 15 Baird Close
Drayton Fields Industrial Estate
Daventry
Northamptonshire
NN11 5RY
contact: Mr Danny Whitrow
Tel: + 44 (0) 1327 706444
Fax: + 44 (0) 1327 706445
eMail: [email protected]
www.rsdcars-uk.co.uk
Jimmy was Very helpful and fast response!.
Hi guys, sorry to re-surrect an old tread but i am looking for a few plastic repair clips to fix a set of shortnose proektzwo headligts, anyone know of a source ? I was even thinking to print a few but cannot seem to find anyone with a 3d printer in romania...
T4 2.5 TDi 2003 SWB
Hi mate,
What plastic parts are you after mate? as far as I know ProjektZwo assemblies don't have 'plastic clips' :unsure: I may be wrong .......... at least mine don't. All steel fabrication.
Would you mean the 'stand-off' for the headlight levelling motors?
If so, there's a post on this forum about making your own out of aluminium tubing somewhere abouts.
If it's to do with the plastic headlight adjusters, they come with the headlight units, usually supplied from Hella. Same units as on the BMW E30 Series 3 I think.
And there's no need to apologise for resurrecting 'old threads' mate, that's what makes this forum great in my opinion, just about everything VW bus has been covered over the years :)
TURK
Update, i got a set of clips machined out of teflon/plastic (about 10 pieces) and cut 2 slits ( in a cross shape) with a hacksaw to make room for the ball ended adjusters and then fitted the headlights...massive, massive improvement especially as they are wired for twin xenon but only used HID bulbs on low beam, let high beams with stock halogen bulbs...Really worthwhile upgrade for two hundred euros i paid for them... Now i will commission local engineering phirm to cut a sheet of stainless steel for me, i will replicate the design and maybe upgrade the light units in them as they draw even less current than HID bulbs... I got pictures of the upgrade but they on my mobile and i don't know the forum password to access the site...
1 - 9 of 9 Posts
