Hello .
Like a lot of us I've fallen fowl of the seductively cheap OBD II leads on Ebay only to find they don't work with the latest Ross Tech VCDS [old vag.com not available now] . I want to time the injector pump and wonder what lead and soft ware to buy! Can anyone help? Either by selling me the right kit or suggesting a good place to find it.
T4 2.5 TDI 97 camper
Danser
Hoping yours is going better than mine.
I have vista and had to reconfigure my settings to get it to work.
I bought an ebay lead for £8 and it works fine.
I'm in Cambridge if you want to borrow it.
Mine is Windows '98 second edition. It works fine with Ross Tech program [probably old] & lead from Ebay.
Is it the lead or the OS?
There always seems to be a problem getting the program to work through the right comport at first.
It has to be Comport 4 (I think). If there's anything assigned to that in manager then the lead gets put on something else & vagcom doesn't see it (although it says it can, but in reality it's looking at a webcam or something).
Uninstall whatever manager says is on Comport 4 and try again. (I think you can manually "change" the port too, but can't remember exactly what I did).
So are you getting to the pump timimg graph with an ebay lead? If so what programme are you using, the shareware or the lincensed for third party leads?:*
