Hi all,
Just leapt on the camperwagon and getting to grips with a 2011 T5.1 140 swb.
Overdue cambelt sorted, along with fluid changes and a thorough flush of the brake and clutch system having found the reservoir looked like miso soup :/
Reverse camera fitted properly after reversing a host of DIY wiring bodges.
Question for you about the ignition switch - which seems a common issue on forum but didn't find any mention of my concern.
The feel between accessory position and ignition is vague at best. In fact there isn't really any click as I expect. Only indication is whether the radio comes on alone, or the ignition lights on the dash illuminate. Similar in either direction.
My question is - does the 'feel' of the position clicks come from the barrel or the ignition switch itself?
I have previously changed a Golf 5 barrel and this just rotated freely with the key, so guess the switch?
Not tried yet, but does the steering wheel really need to come off to remove the column cowl?
Would only fit a genuine one in the hope of longevity- I am guessing £50 or so from TPS?
Appreciate your help!
Euan
Euan
