I washed my engine, after washing it the radiator fan switched on and does not stop even when the transporter is switched off, the only way to switch it off is to disconnect the battery. Is there any way to solve this problem??
Discussion Starter · #2 ·
hi.frend ithink your fam modual is gone i had same problem as your and it was fan modual you can bye from ebay is cheper then vw
