VW T4 LWB long nose 2.5TDI: When parked rainwater is getting into engine bay. Sound insulation on under bonnet at nearside gets soaked. Have checked the scuttle and rubber - OK. Checked screen wash gasket - OK.
Anybody any ideas or had the problem and solved it please? Thanks. Rob.
Hi, did you ever sort this? I have a similar issue - rainwater seems to drip down from below the windscreen. The scuttle rubber is loose so I'm wondering if water can get around it.
