As I cant' find any recent posts ....
Most (if not all) EHU I have read about consist of an RCD and 2 x DP MCBs. Now I'm stuck for space and only have room for a consumer unit with RCD + 1 x DP MCB.
Is a viable alternative 2 x DP RCBO's? I can't find a definitive answer whether a DP RCBO diconnects both poles on leakage fault only or if it also disconnects both L+N on over current?
If RCBO's are an alternative does anyone know of a suitable consumer unit? I need to check dimensions before specifying for my EHU.
Does anyone know of a polarity tester that can be plugged into the EHU post, so test before I connect to the van?
