Is this too loose?
I have never played with diesels before, when i took the injectors out the they were damn tight, but i think this may be due to the carbon and **** built up around the nozzle bore?
I know the fit doesn't necessarily effect the sealing of the injector, but is this too loose?
Just making sure i got the right head.
http://www.youtube.com/watch?v=LJe6HJBkDYM
Cheers Guys.
certainly looks loose but surely when it is clamped down on to the copper washer it wont move,you dont want compression coming past the sides?? are you fitting new copper washers-you should??i have never done before but after reading rakes project power thread he heats up the copper washers on the cooker until they glow red hot then allow to cool at room temp before fitting
if you have any doubts yourself pm rake on here he will give you all the advice you need T:
