1 - 14 of 14 Posts
Hi Guys.T:
Can someone please tell me how to remove the rear door panel where the locking mechanism is as i want to insulate behind it then carpet panel. :*
Thanks Chaps.*<:)>
Dave S.
Yes mate, already removed them but one, dont know how to take lever bit off to be able to remove panel.
Dave S.
once all of the screw/clips are gone - the panel will move over the handle ? or am i missing something :*
The panel sits behind the handle surround, so need to take surround off first, but does it just pull off or some other way:*
if the handle is over the panel you need to push the handle surround it while sliding it to the right, it sort of slots in about 10mm to the left, thats how i got mine off and on when i carpetted the back barn door panels. Good luck.
Not on a T5........it pushes upwards to release.
1 - 14 of 14 Posts
