1 - 11 of 11 Posts
I've cut the rubber down quite a bit(almost flush with the metal part) and removed as much of the metal as possible, and welded it all back in.
No more banging :D
No more banging :D
Hey bud I have quite the issues with my bumps stops as they are as far as I can tell still the standard length but upper and lower rears are touching can I cut them down and fix this issue
If you cut the tubes down too far the tyres will contact the top of the wheelarch. If you can hang on I'll measure the length of my cut down tubes tomorrow, with full size rubbers they only just scuff the arch. Also if going that low you need to grind away part of the flange where the handbrake cables run otherwise it'll cut into the cable
Like this
And fixed
1 - 11 of 11 Posts
