Rear disc and pad removal. Jacking points?
7.4K views 14 replies 6 participants last post by  rob_talisman
My rear bolts will not shift at all, regardless of heat, ring spanner n hammers, big breaker bars or scaffold tube. We took my mates off by grinding the bolt heads off, the calliper will then just pull out, you get the remaining bolt out with either a large stud extractor tool or grind a slot and use a large flat screw driver. Then just replace with new bolts, got mine ÂŁ10 a pair VW OE, from a supplier in Swansea
