Is there an easy earth point near the offside rear corner of the vehicle?
My leisure battery is in the offside rear of my campervan. Currently it uses a very small ~30amp 3mm cable as the earth wire, which goes back towards the front of the vehicle.
I want to replace that wire with a 100amp battery cable but there's no space back to the front (and I can't be bothered to run another long cable run) so I'm looking for a shorter easier option.
Always a bit nervous about hitting something behind the fabric or otherwise of the metal work.
Is it as simple as picking a spot in that corner and cutting some fabric out and screwing in a round connector on the end of the earth cable?
