1 - 10 of 10 Posts
Looking to tidy up the rear headlining in the van, Ideally though I'd like to use a single piece of hardboard front/back with no join T:
I'm struggling to find hardboard wide enough, Any suggestions peeps? Bond a couple of pieces together is the first thought:*
BnQ should have sheets of Hardboard that are long and wide enough...Did mine with it though i cut mine to the two OEM template sizes.
Cheers for the responses guys T:
I measured the roof and it's circa 1300x2100 which is slighting wider than a 8x4'' sheet, A bit of research and it seams that a 5x10'' sheet of ply/hardboard is the way forward T:
Trying to find 5x10'' is the problem though, Next week i'll see whats about although i understand its not cheapI:
Yes 10 x 5 is needed to do it in one piece.
Its not that easy to find, But after lots of serching i found some local.
I use 6mm ply for the roof.
T:
I'll see what comes up locally! I was going to look at 3mm ply, Is the 6mm ply better for the job? I was hoping to use flush fixings so would have to recess them but not impossible I guess....
Mines done with a sheet of 8x4 and some infill panels around the edges
you can just see the back corner on this pic
will try and find some better ones.
Discussion Starter · #8 ·
Little Bump to this thread....
I managed to get some ply from Bences in Cheltenham as a company discount helps I:
3.6mm Far Eastern Plywood 10x5' £18.20 +VAT
12mm Far Eastern Plywood 10x5' £44.20 +VAT
12mm is for the floor T: The prices give you an idea but remeber I had a smidge of a discount (And free deliveryI:)
:ILU:
Damn that's a very good price!
Local lumber yards around me are quoting £100 + for 12mm...
I'm going down the route of splitting one piece from B&Q and infilling the middle with another piece
They had to order it in, But I was quiet happy with the price...
You could bond two sheets of 8x4 together with a backing strip on the join, Or some people have created a light center piece which looks pretty sweet!
1 - 10 of 10 Posts
