i was wondering if i take the rears suspention shims out the van would it cause any problems ? I:
rhino1977 · Registered Joined Aug 17, 2010 · 148 Posts Discussion Starter · #1 · Dec 6, 2010 Only show this user i was wondering if i take the rears suspention shims out the van would it cause any problems ? I:
shiro utsuri · Registered Joined Jun 21, 2009 · 5,259 Posts #2 · Dec 6, 2010 Only show this user loads have removed them as i have . no probs here T:
motobuild · Registered Joined Aug 12, 2009 · 514 Posts #3 · Dec 6, 2010 Only show this user same here,no probs
Big Bad Bear · Registered Joined Oct 3, 2007 · 4,220 Posts #4 · Dec 6, 2010 Only show this user You may want to Double check That!!! I replaced mine with the smaller ones and the spring started to cut it's way through the bodywork
bigcat · Registered Joined Oct 3, 2007 · 9,434 Posts #5 · Dec 6, 2010 Only show this user Big Bad Bear said: You may want to Double check That!!! I replaced mine with the smaller ones and the spring started to cut it's way through the bodywork Click to expand... OOOOPS thanks for posting that, Chris, been on springs only for thousands of miles now. Will be gingerly takin' a real close look very soon T:
jayesrustybus · Registered Joined Nov 7, 2011 · 171 Posts #6 · Jul 4, 2013 Only show this user I've just lowered my rear suspension and i got 5mm shims from http://www.bluebird-type2.co.uk/T4%20suspension%20parts.htm They feel as tough as originals but will see in a few thousand miles:ILU:
