1 - 11 of 11 Posts
Got a 1.9td T4 1997 need a new rear spring two for sale on justkampers which one cheap un on dearer one???
Its on a fully converted campervan hightop so heavy duty im told
Part Number: J12985 £68??
Part Number: J18094 £52.50??
Discussion Starter · #2 ·
Can anyone help? Just want to get the right one
I suspect the more expensive one is the heavier duty one but probably worth phoning them to check.
If one has gone worth checking the condition of the other one too especially as you have some weight in the van. If in doubt, fit Eibachs is what I recon, strong as you like T:
Where do I get Eib's and how much?
They aren't the cheapest option by any means but you get the quality with the outlay. Various places do them, I got mine Here
You will get a -45mm drop so factor that in as no good if you don't want to reduce the ride height too.
Some pics of them in my build if that helps, click below.
Failing that if you do a wanted thread there must be plenty of people who have spare springs kicking about after lowering their vans (you would have been welcome to mine but I gave them away a while back)
Ben
How old are the Eibachs and how much do you want for them? I am very interested in a set
1 - 11 of 11 Posts
