Hi all
i am in the middle of a rear wheel bearing change out. i am now at the point of struggling to get the outer bearing race removed from the swing arm. i have tried pressing it (16mm stud with suitable sized bush) and tapping it with and without heat to no avail. looks like its going to need a hydraulic press.
so my question is.... to remove the swing arm is it just lower shock bolt and the two front bolts or is it more to it than that? will brake pipes just detach with a clip?
any help really appreciated
cheers iain
