What do I check next?
Front working so it's not frozen.
Checked all the fuses
Rear wiper still working so don't think its the switch
I have recently solved this problem this week. This is what i did,
I removed the interor tailgate cover so that the rear wiper motor can be seen. to the left of the wiper motor there is a clip that holds all the wires and pipes. i found the water pipe for the washer here. this is the black pipe. if you relese the water pipe there should be a join there. i diconnected it and started the engine and tried to was the rear window. water was coming out so i knew is wasnt the pump or anything, so i put it all back together and got a needel down the actual jet on the outside and just kept on poking it and trying the washer and poking some more, until evuntually it worked. i then just set the jet where i want it to spray on the screen and job done.
Hope this helps
I too had this problem, sticking a pin down the end didn't work for me so used a pipe cleaner to remove crud from the plastic pipe and cleaned the rest of the pipe out by using an air duster spraying down the jet.
now all working correctly :)
