1 - 10 of 10 Posts
Hi all.
A friend has told me this mod is fine
Just checking really as I dont want the rear windows falling out. My rear window rubbers are a tad perished, is it ok to cut them flush with the windows and not have any leaks or window fall out syndrome.
Ian..
Yes it will be fine. Took my seals out ages ago.T:
the rubbers are the ones that fit over the edges of the glass panes. They are bonded to the doors so shouldn't leak or fall out. I have two in the shed (£25 ish each from vw) to fit when i the van resprayed. In my opinion the do look kack without the rubbers fitted, but thats just my taste.
I'll post a pic up when I get my van back from Tidy T's later on.
I think they look better without the outer rubbers. Much cleaner lines
Took mine out,the only problem is it gets dirty and you have to spend a bit of time getting in there to clean,but overall i like
ian like i said just pull them out youth they will look a lot better and you wont get no rust around your doors. have you had your side windows done ?A:
1 - 10 of 10 Posts
