Same here! Still have my saxo but thats got polycarb windows so no need for a bung, the t5 is its towing machine now lol.Back in my boy racer days I did the same mod on my saxo's.
Early bog standard 106's didn't come with rear wipers so I bought the plastic bung and retaining part from the parts department. Worth a try if you can check sizes!?
I can have a look for you... the T5 is at work and the T4 is with Jay, whats it going on?Abi- I keep forgetting to measure the hole, do you know which size bung I need??
snap, think there aerial grommits, there hung on the racking where the fuses nuts bolts etc areHalfordsT:
They do 3 or so bungs in different sizes as a pack, one which fits perfectly! That's what I run and they are only a few ££ no leaking or anything either:ILU:
Odd as i've used the middle size and it fits well, Halfrauds may have changed them?I used the largest of these (24mm) and it is a sloppy pi$$ fit, mine is more like 27mm
On tailgated vans, I can't see how your going to get to the lock :* but can't comment on barndoors thoughI would like to remove my rear wipers - but am a little concerned over reports that a bung might be easily overcome and allow rear entry more easily (to the VAN!) for thieving chavs & pikeys ??
Is this the case?
rob
maybe my hole is too big :*:*:*Odd as i've used the middle size and it fits well, Halfrauds may have changed them?
time will tell - they are out now :glOn tailgated vans, I can't see how your going to get to the lock :* but can't comment on barndoors though
''Insert whitty response here''maybe my hole is too big :*:*:*
This one:There's a german company that makes a glass one but I cant for the life of me remember it!
Thats the bad boy. Alot of peeps in the vdub scene use them
