Has anybody completely stripped a rear caliper down before, I'm fine with changing the piston seal and dust covers but not sure about the hand brake mechanism. It looks like an internal circlip holds the thing in, however its spring loaded so not sure how I would get it back in If I take it out.
Piston and seals can be changed but handbrake bit can't I believe good luck mine work well now but the peddle goes down a lot further now and is a bit softer as the rears were seized solid handbrake is very good now also
ive just stripped a set of rears and taken the circlip out with some trouble.
the problem is access,i struggled to get a set of circlip pliers to get in to the cylinder
in honesty ime gonna have to find a better set to get the clips back inn.
there must some available somewere for the job.
its very easy to score the bores on the way out with the circlip.
not an impossible job,but not easy either
found a set of double "A" internal circlip pliers on amazon.
perfect for the task.
around $30 delivered but invaluble if you want to do this job properly.
