For sale I have a 3 year old Reimo kitchen unit in good condition with 2 hob burner and sink installed and will take a fridge like the Waeco coolmatic MDC-50 (not included)
Unit measures 63cm wide by 79cm tall by 48cm deep and is white with grey speckles in style with grey trim.
In addition to the space for the fridge, the unit has a pull out drawer for cutlery/ utensils, a tall drawer for plates/ cups etc and a slide out table
Please note the water tap is designed to be linked to a water tank and pump under the van but can easily be fitted with a submersible pump and two 10l water tanks if required.
The unit also comes with all interconnecting wiring and gas/water pipes plus a new gas regulator and hose.
The unit at present is fixed to the factory holes in the floor that would normally hold two mushroom bolts and is very easily and quickly removed.
£300ono.
Thanks for looking.
