If I remember you have to pop off the trim panels on the sides of the dash, that gives you access to the vent units, then you'll need a hex or star bolt to remove the screw from the bracket that sits on top the vent unit - was over a year ago I changed mine though so apologies if its not correct!
This in on a T5.1, I don't know if its any different but I've tried pulling and pulling, after taking of the underneath dash trim i can see a star bolt behind the air vent. will need a stubby type driver to remove it if that's the case, thats why i asked on here first if anyone removed theres.
They are screwed in from the rear. Access behind dash, remove lower panels.... Tricky I'd imagine in place, only ever taken them out on a removed dash.
Thanks, managed to do it in the end. You can get to the screw using a small ratchet driver in from the side, after removing the side panel. Onec the screws removed the air vent assemble pulls out.
