I'm wanting to run a cable through the grommet behind the battery how do I remove the plastic panel under the windscreen behind the wipers?
Any chance you could advise of the exact technique for "prising up" as it's quite a tricky process and I don't want to break it. I want to get to the grommet behind the battery as I think it's leaking water in the cabin. Thanks.
I had a similar issue which turned out to be a drain from the aircon, a drain pipe above the passenger footwell had come apart. Once refitted it has never leaked.
Do you have a sunroof by any chance? the blighters get blocked and comes into the cabin. The outfall is a grommet on the bulkhead and will need cleaning.T:
