Has anybody taken out a dash with an airbag fitted? Can you offer any advise do i need to disconnect the battery or anything before disconnecting/reconnecting the airbag?
ALLWAYS disconnect battery prior to doing ANYTHING to an airbag.
Furthermore I have seen others comment about what clothes to wear; Wear clothes (cotton) that will not produce static electricity as it MAY have an influence on the airbag (some say).
Its very Good that You ask & highlight this issue as I would not want a fellom forum member to have his/an airbag go off while working on the carT:
And then reconnect airbag with battery disconnected? - is it going to be an issue if i run the vehicle while the airbag is removed?
