Hi all
Just been to look at a lovely T4 this evening which is a professional conversion but has a high top.
If I buy it I'd like to remove it and put a pop top on. Before committing I'd like to know if that's even possible?
Anyone got experience of this?
Gary P
I have a high top and only the middle bit has been cut out. If the one you have looked at is the same as mine I can't see why you couldn't remove it to fit a pop top. Also the cut out will have already been strengthened so all you should need is the pop top.
they normally leave the front cab area in and a small section of the rear section
a poptop should fit over it all, you would need to measure it though
Hi Gary,what high top is it ?Can you give me some dimensions and a few pics please?If its a genuine Reimo roof and the strengthening system has been fitted it will only need cosmetic work (painting ect) done on the van roof to make it pretty again before an ER Roof is fitted.Been fitting Reimo stuff for 20 years so hope I can help?
