In my T4 800 Special there is a half bulkhead...which I REALLY dont want and want that to be the first job and get it out asap!
Could anybody please give me some guidance on how to remove it!
Bradley!
T:
Be careful removing the bulkhead , drill out the spot welds or go easy with a mini grinder, or chisel it out, BUT Remove the seat belt reels as heard storys of them going of on the pre tensioners, chieled mine out and now just a few little bits to grind off
remove the seatbelts !!!! cause a set the drivers one off on mine and it sure scares the $hit out of you,that said it's easy enough,spot weld drill,angle grinder and a hammer and chisel is all you need T:
Drilling the spot welds out is the way to go. An angle grinder is also the way to go. I also found the use of a reciprocating saw was invaluable!!!!!
