Replace 1.9tdi BRS with suitable equivalent?
1 reading
32K views 13 replies 4 participants last post by  Bobby123
#1 ·
So my understanding is all the VAG 1.9tdi engines are essentially the same, but all have different codes and outputs? My BRS engine is apparently on its last legs, breakers want a huge amount for any engine labelled 'transporter' but golf, Passat, a4 engines are all cheap. I know the main difference between BRS BRR and AXB AXC is the crank sensor which is in the rear crank oil seal so I matched that part number with a whole bunch of engine codes from VAG cars, so they have the same sensor. But what else is different? Manifold, turbo, EGR all look different on these various engine but I can swap all that, cam cover looks a little different on some, also can be swapped. I couldn't find much on the forum or elsewhere about the BRS or BRR engine compatibility. Anyone managed it? :*
#5 ·
Thanks for the info, quite simple part swapping then although it seems like it's everything bolted to the base engine is changed. I might end up with a used complete T5 engine to save the time of building it up. Seems a lot of the other model engines I've found are high mileage anyway.
#13 ·
Yup I have done some searching and found BXE and BLS are both considered weak rod-throwing engines. BKC has been mentioned as apparently the older models are stronger. I can't find, or afford, a T5 engine that's suitable, stupid rare BRS/BRR. So I think i'll try a BKC and build it up using the parts from my BRS and i'll source some newer injectors of the same part number to fit it, and a new turbo CHRA. Should get a decent engine from all that for less than a used BRS.
#14 ·
Hi guys
How did you get on fitting the bkc into your t5?
I have a brr t5 that has coolant issues(pressuring no heaters etc etc)stripped the engine to find cylinder one has suspect water/coolant marks .so I'm looking to put a re con engine in rather than spending lots on a knackard unit
Any help would be massively appreciated
Bob
