1 - 10 of 10 Posts
just trying to get all the bits to swap out the standard stereo with something a little better but trying to get all the bits so not to get stuck half way. can anyone tell me if i will need one of those adapter things for the wiring loom that goes in to the back of the stereo to avoid cutting and joining the wires and if so which one would i need.
many thanks charlie
Most stereos you buy have a short loom to the ISO connectors.... this just plugs into the connectors behind your dash... job done.
Replaced mine with an Alpine unit recently... took 25 mins and that was taking it slow and fixing the cage for new unit as never dealt with a T4 before!
cheers nice one i seam to rember most of the more modern cars required some sort of adapter to convert between the two so was ondering if that was the case with t4,so great if nothing else is needed.
cheers nice one for that never new that last time that happened i assumed the stereo was duf lol many thanks
Hi sorry to hijack the thread, but sdo you need any specialist tools to get the orginal stereo out. I have the cassette deck in my 02 2.5tdi. I have some old tools i got for past head unit but none of them look applicable to this.
Due a new headunit anyday, come on postman!!!
swaped mine over this eve,mine was a tape dec aswell it had one poit at the top left that had to be relised.just fine something thin and flat to slide down the hole or alternativly unscrew the faceing bit and just flick the thing with a screwdriver and it pops out.
the plugs did go right in the back of the iso no wories but it does need the two wires switching as it is loosing its memorey. just got to figer which two it is.it was a very quick job
next is to figer were to run a power lead from bat to amp and then the sigle ones from headunit to amp.
Discussion Starter · #8 ·
well i changed the two wires thismorning (after reding the instruction) and all i got was the distinct smell of burning electrics:* i unpluged very quick but think it was to late seam to still get power but the face has no signs of life. i put the broken old one back and that now only seams to work on the ignition setiing no when the van is running so im even more confuzed.now have a weekends driving and camping with no sterio and not able to afored a new one guted!
Discussion Starter · #9 ·
problem slitly overted the sterio is ok but the guy who tested it said there could be something up with some switch in the ignition barrel. any one have any ideas what that would be? cheers
1 - 10 of 10 Posts
