Getting great trips in the Syncro recently but have noticed a resonance appearing in rear left between 55 & 60 MPH. I tried changing tyres first just in case the noise was from the tyres. The noise remained on different tyres.
So I put the original tyres back on. A few weeks later it got worse so I replaced the left wheel bearing as I thought that would solve it & left wheel bearings were well worn. Differential was refurbished a few months ago too. Next thing it could be causing this noise is the rear drive shaft I think.
Before I go dismantling that anything else I should look at first? :confused:
they all do it to some extent at certain speeds its normally wheel bearing or the prop bearings, if its not the diff or cv's
