I would like to know if the factory seats have the fixings for the arm rests fitted as standard but not the arm rests unless orderd with them
my research suggested the factory seats have both armrest holes pre drilled ready to accept armrests on both sides.
in the end i bought a matching pair form the vw guy in poland, these both had the inside armrests. and i haven't bothered trying to put outside armrests on as i just use the door card.
I believe all seats have designated pre cut holes, mine 2008 had. I bought on eBay one drivers armrest off Sprinter, but luckily it came with bracket which you need to bolt on to your seat and then you fit armrest. All were original parts. The bracket looked like a bit of triangle, even seat foam had slightly pre cut square for armrest to go in to, so that you don't have to guess. Hope it helps.
