I changed my clocks for a set from a later model that had a rev counter. Luckily it worked straight away. Mines a 94 so chances are most are already wired up. I know others use the cluster from a Passat or some Audis. Just make sure to use ones from a diesel if you are running that and check to see if your Speedo is cable or electric.
Hope that helps
Somebody stop me!
cheers for the replay - have the old display , and did get hold of a later one with the rpm counter but the wiring up is completely different.In addition the newer one is curved and couldn't see how I would get it to work without replacing the dash .
Is there an after market one people would recommend ?
THere are not many to choose from for diesel engines TBH, take your pick T:T:T:
