Reverse lights not working, all fuses ok none blown, bulbs not blown, is there a switch somewhere that could be faulty? Thanks in advance,
You should be able to bypass the switch just join the wires together that go to the switch and the lights should come on if they do its gearbox end if they don't its wiring
I've got the same problem - no Reversing lights and no parking sensors, so tomorrow I'm going to give it the once over and I'll report back anything interesting / useful discovered :)
Fuse location:-
My T5 is 2012, fuse for reversing lights was underbonnet in fusebox near battery - mini 10amp fuse (fuse 15 in mine)
All sorted on mine. It was the switch that goes into the gearbox. I bought the replacement from www.eurocarparts.com - £10.08 part no: 465440140. On the box it also says "2K42F". I'll post some photos of the job when I work out how to do it on this forum thingy :). My vehicle is 2005 T5 1.9TDI.
