Newbie question here - can someone please give me a pointer on how to remove the pins which hold in the roof lining panel?? the first one I tried I managed to tear the edge of the roof lining to want to keep the rest of it intact!
they have a little allen key bitty in the middle you unscrew them ( which brings the center out) and then they just pull out quite easily, dont try to use the board to pull it cos it tears the board.
if they just turn and dont unscrew either use a bit of side to side jigulry, or help it to screw down with a little preassure from a thin screwdriver or knife ( on the middle bit not the outside bit they will sheer if you try to pull them out from the outer edge)
also if you save them they do go back in with again a bit of jigulry
get yourself a trim clipremoval tool from a motor factors, £5 dont even need to bother unscrewing them, you can ease them out without damage in no time at all... or make your own tool from a narrow walpaer scraper...
