Is there any way to get the internal plastic screw things out if the hex shape is worn? Every time i take the panels down i wreck more and more. Only got about 4 holding the thing up now!
Also can someone point me in the direction of the person who sells the black ones.
Use a small self tapper. Screw it into the the hex bit until the centre starts to turn then grip the screw with a pair of pliers and pull. The plastic clip will pull out without damage, then un screw the self tapper. Quick and easy and doesn't mark the clip at all. replacements from VW at about 30p each.
