Hi peeps
Help/ideas please :)
T4 lwb standard set up,running 195/15/55,recent new steering rack and lower ball joint fitted, not sure which side.
The van seems to rumble/vibrate up and down on the front end.Would this be something like shocks ? Or maybe tyres ?
And help advice greatly received T:
Cheers.
Might be a daft point but after the rack was replaced did you get the tracking done. As already stated wheel balance can cause wobbles but you should feel this through the steering wheel at a certain speed. Because you have had work done on the steering you can inadvertently cause a knock on effect. I had rumbling and after replacing both bottom joints it was still a bit knocky, the cure was to do the drop links as well. T:
