they look the nuts .and o so comffyGot Saab 95 seats in mine, they are a couple of inches higher, but still ok to drive (I'm 5'11"), I have cut down the passenger base only because I've got a swivel fitted. Comfy seats though T:
they dont look to high at all. i missed out on the pair i was watching .so will keep looking.im 5/8 and find the ride hite just wright in mine![]()
Hi can you let me know the measurements of the base of the rear seat please. would like to see if i can get one to fit my
£20 can't fault that. will give that avenue a tryI Got Saab 9-3 turbo seats in mine, (£20 the pair from the local scrappy)
if anything i would say they are slightly lower than standard seats, But can be raised by adjusting lever. They bolted straight onto the base with two new holes drilled and slotted at the front (half inch wider each side). They are on CMC swivel bases .... takes about an hour per seat realistically if you take your time
Luke
