and I'm going to look at T4 camper untill i saw it had a replacement 1900 SDI engine, havn't a bloody clue what there supposed to be like TBH, any help apreciated [starting to think we'll not be on rd for august holidays at this rate].....
Hoping its not the italian based VM 2.4 Diesel with an Exhaust driven wind pump that was fitted to the Rover SD1 many a moon ago. Run away run away. :)
Banned
the sdi is the most basic engine available in current range of vw diesel engines
standard diesel injection
no turbo
1.9 turbo`s are normally regarded as lacking power in a t4
this van is probably underpowered.
Meithered to death
Same as a TDI but without the Turbo,SDI's are normally aspirated but with direct injection and are ecu controlled and fly by wire,if its in a T4 then it probably has the old fuel pump on there and is cable operated.
