Hi, Can anyone talk me through how to remove the seatbelts and remove A&B pillar trims so that I can remove the rest of the bulk head flange. I've done the floor section with a junior hacksaw and pliers. Despite being very nervous, having read a lot of threads on here, it was easier than expected. I have bought a m10 spline bit for the head bolt already.
Anyway any advice will be most welcome.
Hi mate, if you've removed the main part by sawing it off, you've done the hard bit! The plastic trims need to be pulled/pryed off... some of the plastic fixings may bend or snap or stay in the female part of the plug, but you can only hope for the best, and if needed, get some new plugs if they break. As for the spline tool, the top cover on the seatbelt opens up to expose the bolt, then just undo the bolts! The top part of the bulkhead then just unbolts.T:
