Evenign all, I'm having a mare tryign to remove the two front bolts from the seat rails to the bases. The rest of the bolts were really tight as well but came out with a lttle brute force.
But the front front seat bolt on the drivers side won;t budge, on trying one i made the hex head nice and round, EEK.
and the other is stuck and just won;t budge. On closer inspection i think both the front bolts have been bent over years of sliding back and forth.
anyone else experienced this and has a nice solution?
Weld a bolt onto it is a sure fire way to get the things out, the heat off the welding loosens the bolt and you have a good bolthead to get some purchase on.
The above solution is useless if you dont have access to a welder though.
