Hi I have the following for sale:
standard short nose grille with badge (a couple of small cracks which could easily be repaired with superglue) you've all seen what they look like £15
front seats from a '99. Standard non folding double with seatbelt and drivers seat (but no base) in good condition
very minor wear on drivers seat
Alfa 156 rear leather grey seats, they fit perfectly across the full width if you built a frame but to be honest they're taking up too much space at the moment
And I have the Alfa 156 door cards; all four, free if anyone can use them.
I'm in Bristol but I'm happy to deliver or meet within reason, And I'm looking for another single seat base if anyone wants to make a deal.
They're on ebay below now so I'm going to let the auction run
sure it's from a 99 plate (the newer type with the blue dash if that matters)
looks like this:
you can see the small crack in the bottom left looks like this if you pull it apart:
and this if you put it back together (if you glued it you wouldn't know if was ever broken:
I'm only selling the black plastic grille, not the white metal front panel. Hope this helps T:
