Reading this one with interest. I have bought a Numax sealed battery CVX XV31 113a/h which has the following dimensions: 330mm long, 170mm wide & 241mm tall. It says this is a sealed battery. I have seen quite a few batteries mounted inside the cabinets & I was going to fit it just infront of the rear wheel arch. I am a little concerned about the gassing problem & I see that there is a possible solution, by mounting it in the engine bay. This gives me other worries though. I have a sterling 600w inverter on the way & a Sterling 10amp battery charger. Both of these items state that they should have the shortest wire run possible I was going to mount these items in the rearmost space above the wheel arch. With the battery being in the engine bay & the other two items at the rear of the van, I am looking at a wire run of about 5m. Too long I think.
So, can I mount the other items closer to the battery, or can I mount my battery in the cabinets?
Also, I have tried to locate the numax website, but it is so far eluding me. EDIT found
here
