Hi All
Looking for recommendations for a 'specialist' in St Albans area.
We have a 1996/97 LHD T4 2.5 Tdi ACV with turbo/power problems. Engine starts and runs ok, but lacks power - struggles uphill, and doesn't feel like the turbo is working.
Replaced MAF and 2 pin coolant sensor, checked N75 readings. Disconnected/reconnected MAF - no difference. Replaced all vacuum hoses with silicon pipes. Local garage say Actuator is faulty (not convinced by his diagnosis). He said there were 3 fault codes.
1. 2 pin coolant sensor (replaced)
2. N75 valve intermittant
3. Throttle position sensor intermittant.
I'm guessing it will need another VAGCOM check, and I'm hoping someone may be able to point me in the direction of someone who knows a bit about these beasts.
T:T:
T:T:
