As per the photographs below two R8 lights for sale these are of the proper UK RHD type for the T4 short nose.
These rarely come up for sale so I would looking for £110 posted and pay pal to the UK or £90 cash collected from BN10 (just East of Brighton).
They were on my van for just under a year and were removed well over six month ago as I was de-pimping to make it look more standard
These have never been used with HID bulbs so the lens is not melted or damaged in this way. I would describe them as in good working order but not perfect.
As detailed in the photographs there is a damage to one mount on each light which has been plastic welded up the reason for this is that as most people (see www.vwt4forum.co.uk/showthread.php?t=154883) had a bit of trouble getting them to fit well and I was told that using the grommets from the original headlights helped (it doesn't it damages the mounts) just using the standard bolts and a few washers to help align them they passed the MOT beam pattern (after adjusting the screws) and sat in my van happily until removed with no further damage to the mounts.
I note that all of these audi DRL lights are of the same plastic Chinese construction and require a bit of fettling for perfect alignment / fit as these did.
Final note I often have to work away from home for 4 days or so and as much as I am at home for the next 3 days after posting if I am away it may take me upto 4 days plus courier time to get them to you, I will let any one know though if this becomes the case T:
