I know just about everything has been covered on these lights ( myself well an truly inc ! I: ) but I'm just getting round to taking one light out ( due to lost adj screw for up and down adj ) before it goes in for MOT .
But has anyone had to set up light levels ( up / down ) on beam , and how have you done this , ( oh , and left/right adj ) or is it a garage job ? I: SURELY not !!!
When I mean set up , I don't mean ' how can you adj it ? I'm looking at how to find the correct beam height , and how to take reference ? :*
Someone put me out of my misery as not heard or found anything on this subject ? :*
Yours forever gratefull . :cheers
To be set correctly the light beam needs to be shon into a beam setter it measures the amount of light and has a pattern inside which shows the correct alignment up and down and side to side the mot guys may set it for you if you ask them nicely
i swapped mine over in the garage.
Before I took the old ones out I turned them on and marked the wall with msking tape.
put the new ones in ans matced the pattern to the tape on the wall........ Job doneT:
passed MOT with no adjustment needed....
there were adjuster screws in the back for the beam.......
Paul
